Activity Forums Adobe After Effects Axis Mode Bug
  • Axis Mode Bug
    Posted by Jonathan Marino on March 5, 2013 at 9:56 pm
    Hello,
    Just recently I noticed that after switching my axis mode, I can no longer single out a particular axis.
    Example:
    Create solid
    Make 3D
    Rotate on Y-axis any amount
    switch to world axis mode
    switch back to local
    try to move only on the z axis
    you’ll notice that both the z and the x coordinates change
    Do the same with a rotation on the X-axis
    you’ll notice that both the z and y coordinates move.
    This is defintely a new bug.
    Any help out there is appreciated!
    Jason Sutter replied 12 years, 2 months ago 3 Members · 2 Replies
  • Vishesh Arora
    March 6, 2013 at 10:35 am
    Jonathan
    Create solid
    Make 3D
    Even if you don’t switch the axis, You will get the same behavior.
    Reason:
    The moment you Rotate a 3D Object on any axis, Its Orientation starts intersecting the default X,Y and Z axis of AE Coordinate System. Thus when you move an object in Z-space after rotating it in Y-axis, you will notice that X coordinates are changing too as now the Orientation of Object is such that It is moving in both direction according to Default AE Coordinate System.
    For Example:
    Create a Solid, Make it 3D and rotate on X-axis.
    Now move it in Z space and you will notice that Y coordinates are changing too.
    This happens when you are moving the object in Composition using Axis handles.
    If you want to move an object in just one coordinate, Change the Value in Transform Parameter.
    Hope this may help.
    And Its not a BUG.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Jason Sutter
    July 8, 2014 at 12:24 am
    I beg to differ – it is a bug.
    Try moving an array of multiple objects in different quantities multiple times. Using the rotation tool and typing in a value into an orientation or rotation field has the same effect and world axis is not honored by AE.
    Maybe I’m wrong though!
    I’m doing a Rubik’s cube animation which should have been simple once the scene was set up. The first few moves go alright but when I get to the third move the scene (cube) starts to fall apart by rotating in different directions.
    My single cubes are set up as pre-comps, my main cube and all the anchor points of the single cubes are set to the center of the scene and offset to their respective coordinates.
    Something that should have been easy in world axis mode – choosing nine cubes and rotating them, and then choosing another nine cubes and rotating them and so on – cannot be done.
