Activity Forums Maxon Cinema 4D AXIS Center Plugin and 9.6
  • AXIS Center Plugin and 9.6
    Posted by Glenn Takakjian on June 7, 2006 at 5:37 pm
    There is a great plugin I used to use called Axis Center. Worked great in 9.1 Now it doesn’t show up at all in the plugins pull down.
    This is NOT the ChocoTools plugin. It is someone else’s (can’t remember) It gave you the ability to offset the center, center between multiple objecs, children, etc.
    Does anyone know if there is a workable version for 9.6?
    TAK
    Glenn Takakjian replied 20 years, 3 months ago 2 Members · 2 Replies
  • Colin James
    June 7, 2006 at 6:38 pm
    it works for me in 9.6, just make sure you’re using the PPC executeable of c4d, instead of the universal binaries (some plugs dont work w/ UB yet)
  • Glenn Takakjian
    June 8, 2006 at 6:18 am
    PPC did the trick… Thanks
