Activity › Forums › Adobe Premiere Pro › Axio file compatibility on another computer
  • Axio file compatibility on another computer
    Posted by Bob Cole on October 3, 2005 at 3:02 pm
    Currently, I can export my Matrox DigiSuite files from discreet edit* to another computer running After Effects, using Matrox’s software only codec.
    Would I be able to digitize files on the Axio, and run them over for After Effects work into another box which does not have Axio installed — and round-trip back into the Axio/Premiere Pro box?
    — BC
    Ken Adolph replied 20 years, 12 months ago 3 Members · 2 Replies
  • Aaron Strader
    October 3, 2005 at 3:15 pm
    Yes, there’s an Axio VFW codec installer for the Axio install DVD.
    After that Axio footage will run on other systems. The only caveat about this is you DO NOT want to install this on an exsisting Matrox system. If you do it will ruin your exsisting Matrox system, and you’ll need to reinstall it.
  • Ken Adolph
    October 4, 2005 at 12:24 am
    Yes, we found this out the hard way. We were hoping to keep one of our DS boards running as a framebuffer for Combustion/Max on our graphics machine. We installed the Axio SW codecs and the machine quit. It’s to bad that matrox can’t fix this problem! We had to buy a decklink card in order to get framebuffer for Comb/Max. I would have paid Matrox for the SW codecs if they kept my DS board working.
    Ken Adolph
    Media Group
    Editor/Post Supervisor
    https://www.mg.ca
