Activity › Forums › Adobe After Effects › Awkward Audio Looping
  • Awkward Audio Looping
    Posted by Lillian Young on August 9, 2010 at 2:41 am
    This has never happened before. I had a perfectly working comp, then I added a wav audio file and things went bezerk.
    My aiff files went out of sync, looped for no apparent reason, and in a place where I lowered the wav file’s volume, a non-connected aiff file’s volume lowered. The Twilight Zone??
    I cleared the cache, deleted the wav file, closed the project and even created NEW versions of the audio tracks. But each time I re-imported them (different names and all), they’d play normally for a few seconds, then LOOP.
    My comp consists of:
    A movie (of an effect, animation, 30fps)
    A PSD image sequence of the video I am trying to export
    Two aif stereo files from FCP 7 that I layered just fine in the past until now
    Comp frame rate is 30fps
    I even tried to interpret the audio footage. In that dialogue box, Loop is set to 1. I tried to set it to 0, but it resets to 1.
    I can’t think of anything else. At this time, I’m just adding the audio in FCP, but that’s not okay. Something’s wrong. Any ideas?
    I
    John Grote, jr. replied 16 years, 1 month ago 3 Members · 2 Replies
  • David Johnson
    August 9, 2010 at 3:18 am
    That is indeed very weird … the only thing I can think of is that I’ve heard there’s some kind of issue with AIFs in CS5 … I’m still on CS3 so I can’t confirm, but you might want to search for some info about that and, if it seems legit, transcode the AIFs to WAVs.
  • John Grote, jr.
    August 18, 2010 at 12:36 pm
    Well I’m glad I’m not the only one that is not losing his mind. But I do have another problem and I think it has to do with the new Mac towers, because I have had an audio issue on AE 3 and AE 5 on different machines. Has anyone encountered this problem? My audio when I play it back at a different time in the comp it loops back to the beginning. Very strange. Any help would be greatly appreciate.
    Cheers,
    John Grote, Jr.
    J. Grote, Jr.
