Activity Forums Adobe After Effects Avoiding Particle Collisions with Camera (for Starfields)
  • Avoiding Particle Collisions with Camera (for Starfields)
    Posted by Gern Blanstein on May 4, 2015 at 7:12 am
    When I create traveling starfields (stars moving toward the camera or away), it sometimes happens that a ‘stray’ particle will pass too closely to the camera (or to the viewport), which tends to ruin the effect in my opinion. This is particularly a problem with longer sequences.
    I understand there aren’t really any stray particles, but is there a trick for avoiding proximity with the camera or viewport?
    Walter Soyka replied 11 years, 4 months ago 2 Members · 3 Replies
  • Walter Soyka
    May 4, 2015 at 11:52 am
    [Gern Blanstein] “I understand there aren’t really any stray particles, but is there a trick for avoiding proximity with the camera or viewport?”
    Under Physics > Air > Spherical Field, you can create a spherical field which attracts or repels particles; putting this in front of the camera would create a “bubble” around which particles would wrap.
    You could also use a layer emitter with a hole in it, sized just outside the rostrum, and use it to fire particles away from the camera into z-space, then time-reverse the entire animation.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Gern Blanstein
    May 4, 2015 at 12:56 pm
    Two good ideas, Walter. Thank you!
  • Walter Soyka
    May 7, 2015 at 5:18 am
    Here’s a third idea, much simpler than the others. (You can decide if it’s good): use Particular’s Near Start Fade and Near Vanish parameters (under Visibility) to fade or cut stars out as they approach the camera.
    Walter Soyka
