Activity › Forums › Apple Motion › Avoiding on a Bezier curve
Posted by John Mendelsohn on July 9, 2014 at 1:40 amI want things to move linearly! How can I prevent them curving? Also, I continue to have a devil of a time figuring out how to change the duration of an existing project.
Robin S. kurz replied 12 years, 2 months ago 3 Members · 5 Replies -
Mark Spencer
July 9, 2014 at 2:02 amYou can change the interpolation by right-clicking the keyframes in the Canvas or you can do it in the Keyframe Editor.
To change the project duration, select the project layer in the Layers List, go to the Inspector and change the Duration field.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
https://www.applemotion.net -
John Mendelsohn
July 9, 2014 at 4:16 amMany thanks, Mark. Solved the interpolation problem, but I see only my various Groups and their contents in the Layers window. No sign of a project lyaer.
Mark Spencer
July 9, 2014 at 4:23 amI’m assuming you are using Motion 5 but sounds like you are not. Maybe it’s time?
Mark Spencer
John Mendelsohn
July 9, 2014 at 4:24 amFound the Project layer, and adjusted the duration. Many thanks.
Robin S. kurz
July 9, 2014 at 10:32 amClicking on the stopwatch in the dashboard also switches from timecode to project length, where you can also enter a new value i.e. project duration.
