Activity Forums Apple Final Cut Pro Legacy avoiding nesting and dual standards DVD burner
  • avoiding nesting and dual standards DVD burner
    Posted by Yervant on May 1, 2005 at 9:21 am
    working on a long form project and being a greenhorn, I’d like to know what workaround there is to working on different sequences and slapping them onto an ongoing roughcut sequence without the roughcut being considered a nested sequence (so tha I can have the option of communicating w/other NLEs for finishing).
    also, is it possible to have 2 superdrives – one PAL and the other NTSC on my g4? This locking into either standard is very annoying
    thanks,
    Y
    FCP 4.5, MDD Dual 1GHz, 2Gb RAM, Radeon 9800 Pro
    Graeme Nattress replied 21 years, 4 months ago 4 Members · 5 Replies
  • Walter Biscardi
    May 1, 2005 at 9:26 am
    [Yervant] “I’d like to know what workaround there is to working on different sequences and slapping them onto an ongoing roughcut sequence without the roughcut being considered a nested sequence”
    When you’re done with the individual sequences, just do a “Copy All” in the sequence and then “Paste” to your main rough cut sequence. This will bring the entire edited timeline into your rough cut without it being a nest.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Graeme Nattress
    May 1, 2005 at 1:22 pm
    And for Standards Conversion look at http://www.nattress.com
    Graeme
    http://www.nattress.com – Film Effects for FCP
  • Vincent Rice
    May 1, 2005 at 2:59 pm
    Not sure what you mean here. DVD drives only lock to a particular DVD region playback, nothing to do with NTSC/PAL
  • Yervant
    May 4, 2005 at 5:12 pm
    it may not be a standards issue per se, but region 1 is by default NTSC whereas region 2 is PAL. But, yes, my question is whether I could run a region 1 as well as a region 2 superdrive in the same G4.
    thanks for the nesting issue. going by the Apple manual alone can get confusing!
  • Graeme Nattress
    May 4, 2005 at 5:15 pm
    All of Region 1 is NTSC, but Region 2 encompasses Europe and Japan, and is hence both PAL and NTSC. Indeed, the TV standard (PAL or NTSC) can be set independent of region code.
    Graeme
