Activity › Forums › Adobe After Effects Expressions › Avoiding field mush when stabilizing interlaced footage
  • Avoiding field mush when stabilizing interlaced footage
    Posted by Denizen on May 5, 2006 at 12:56 am
    I’m stabilizing two clips in order to composite them and haven’t gotten any satisfactory results with any of my experimentation so far… which has resulted in various flavors of field mush. In addition to interpreting the footage to separate the fields and rendering fields on output, I’ve told the motion tracker to “track fields”, and have even written an expression on the resulting anchorPoint keyframes to round them to the nearest multiple of 2. I’ve also tried preprocessing the original footage with the FieldsKit DeInterlacer. What I haven’t yet tried is doubling the comp framerate to 59.94 so each field gets its own frame.
    Are the following assumptions correct?:
    1. If you do not separate fields and the comp framerate is 29.97fps, a single progressive frame will consist of two interlaced fields, 1/59.94th of a second apart in time.
    2. If you do separate fields and the comp framerate is 29.97fps, each frame will appear to contain only its first field– the second will be interpolated. In this case, the second field of the footage will be used for the second field of the render when rendering fields. If you do not render fields, will the second field of the source footage be discarded?
    3. If you do not separate fields and the comp framerate is 59.94fps, the frame will consist of the two interlaced fields (as in “1.” above), and that frame will be duplicated.
    4. If you do separate fields and the comp framerate is 59.94fps, each field of the source footage will get its own frame.
    Do any of you have experience doing this? Any suggestions?
    Any pointers are much appreciated!
    Denizen replied 20 years, 4 months ago 2 Members · 2 Replies
  • Dean Sensui
    May 5, 2006 at 1:21 am
    In one of the sessions at NAB the other week, Wes Plate recommended to “field seperate footage” if there’s significant rotations, speed changes, etc, being done.
    There’s a full explanation in the help file of Adobe AE. Type in “field seperate footage” in the “search for” field and it’ll find the page with the info.
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Denizen
    May 5, 2006 at 6:09 am
    > to “field seperate footage” if there’s > significant rotations, speed
    > changes, etc, being done. There’s a full explanation in the help file
    Yeah that’s what I said I was doing in the original post. Each of my experiments so far has involved setting AE to interpret fields (and AE will automatically separate fields in DV footage anyway).
    The manual in this case isn’t particularly helpful 🙂
