Activity Forums Apple Final Cut Pro Legacy avoided tape trouble/ error message while digitizing
  • avoided tape trouble/ error message while digitizing
    Posted by Jason Noto on August 6, 2007 at 6:22 pm
    Any suggestions on how to avoid getting a “tape trouble” or “dropped frames” error message while I’m trying to digitize from my Beta deck, so that my tape can import without interuption?
    Thanks. I appreciate any insight and info you are able to share
    Jason
    Gordon Gurley replied 19 years, 1 month ago 5 Members · 6 Replies
  • David Roth weiss
    August 6, 2007 at 7:14 pm
    What format are you trying to capture? What type of media drives are you using?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Jason Noto
    August 6, 2007 at 7:55 pm
    I am using a Beta SP format; my deck is a Sony UVW-1800 Betacam SP, and I am importing to an external EZquest 250 GB firewire hard drive (which has about 180 GB of free space). And I have FCP 5.04 software
    Jason
  • Jason Levy
    August 6, 2007 at 7:57 pm
    Did you check that your device control settings have the protocol set to “Sony RS422”?
  • David Roth weiss
    August 6, 2007 at 11:00 pm
    [JNdigital80] “I am using a Beta SP format;”
    If you are trying to capture as 8 or 10-bit uncompressed your single drive cannot sustain the necessary throughput so you are dropping frames. Try capturing as DV or DV50, your single drive should definitely be able to handle that.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Michael Gissing
    August 7, 2007 at 12:07 am
    I capture PAL 10 bit uncompressed to Lacie firewire 800 frives without problem. Don’t know about your drive so I suggest you run a drive test. If you have a Decklink card, it comes with disk speed test software. I am sure Kona has a similar tester.
    Also it is recommended that both FCP and the SP deck get reference video. If you don’t have an external reference, then your capture card should be able to generate a reference to put into the SP decks ref in.
  • Gordon Gurley
    August 7, 2007 at 7:04 am
    Are you using a Kona card? AJA has a fix for this. Email AJA tech support and they should send you a script that should do the trick.
    Gordon Gurley
    Director of Operations
    Stanford Video
