Activity Forums Adobe After Effects Avoid to loose quality zooming/scaling vector compositions in after effects?
  • Avoid to loose quality zooming/scaling vector compositions in after effects?
    Posted by Alex Vladsh on January 8, 2012 at 8:15 am
    This is a question for experienced users in Adobe After Effects.
    0) create a new project with main composition in AE
    1) create a inner composition (any size)
    2) place any vector graphics, such as text made by AE
    3) go to main composition and place the compositino with vector graphics
    4) create a camera
    5) zoom in changing position, or increase scale of inner composition, the result is always same: the composition is loosing resolution, the final result is very pixelated.
    How to work with big compositions to avoid this problem, if I use a lot of zoom in, and dont want to loose the quality, i have to work with all the objects inside main composition, and forget about pre-composite?
    Andrew Somers replied 14 years, 7 months ago 2 Members · 1 Reply
  • Andrew Somers
    January 16, 2012 at 2:44 am
    For best quality, you should *always* turn on “continuously rasterize” for layers using vector graphics, no matter if they are nested or not.
    The “continuously rasterize” (aka collapse transformations) switch is the one that looks like a little gear, immediately to the left of the quality switch, in the layer switches pane in the comp’s timeline.
    NOTE: If you are using nested comps, the rasterize button *must* be turned on for that layer in the main comp, AND for all the vector layers in the nested comp.
    As far as if you should nest – nesting is very valuable way to keep multiple related elements together. If you are using Illustrator with multiple layers and groups, then bring them all in as a comp so you can keep them together, and yet still maintain independent control over the various groups/layers.
