Activity Forums Adobe Premiere Pro Avoid quality loss from scaling video in Premiere?
  • Avoid quality loss from scaling video in Premiere?
    Posted by Ryan Jackson on September 23, 2009 at 10:54 pm
    I recorded some video in DV format, 720×480, and would like to use it to create a small internet video with a resolution around 320×240. I created the project in Premiere Pro CS4 as a 320×240 project, then proceeded to import the DV files. I was figuring I could just scale the clips one I drop them onto the timeline. The quality looked poor from the preview, but I was hoping they would look better once rendered. Well, to my disappointment they look horrible–very blurred almost as if I was upscaling video (rather than downscaling it).
    I am wondering if there is any way to scale it without the quality loss. I would like to keep the versatility of being able to scale it on the timeline because there are certain portions of the video I would like to zoom in on, and others I would like to zoom out.
    Any tips for improving quality within Premiere, or do I have to use an external program like VirtualDub to do the scaling before I import it?
    Marc Lipman replied 15 years, 12 months ago 3 Members · 2 Replies
  • Ann Bens
    September 23, 2009 at 11:11 pm
    Make the project the same size as the footage which is dv then render to flv, it is quite good.
  • Marc Lipman
    September 25, 2010 at 8:10 pm
    i have the same problem, and I will try your advice…
    but, if a project is already started, can you change the resolution settings?
    also: if its best to start on a clean slate, then if I want to copy edited layers from one project to another, (so I dont have to re-edit the entire thing),, can it be done, and how?
    thanks
