Activity › Forums › Lighting Design › avoid green spill from grass
  • avoid green spill from grass
    Posted by Josh Williams on May 30, 2019 at 11:59 am
    Hi there,
    I have recently shot an interview in a field with the subject sat fairly close to the grass. As I often am, I was travelling fairly light. I had an assistant holding either a bounce when it was cloudy or diffusion when there was bright sun and that’s it. the only light I currently have doesn’t do much in bright sunlight.
    What would my options be for blocking this green spill on to the skin tones? It was only in the bright sunny conditions really, when the sun was obviously reflecting the grass on to his skin. My thoughts so far are:
    -Black material on the grass immediately around him
    -Increasing the light on his skin with a thinner diff/reflecting more light back on to him
    -bringing a more powerful light to work as a fill light so using no diff…
    see example image- Bright sun, diffusion casting shade on subject and no other influence
    Mark Suszko replied 7 years, 3 months ago 3 Members · 2 Replies
  • Erik Anschicks
    May 31, 2019 at 2:26 am
    Your first solution is probably the easiest and best if traveling light. You could also try the opposite, using white bounce laid on the grass instead of black, or some combination of the two. I’ve used an 8x or 12x of Ultrabounce in these cases, which is SLIGHTLY off-white and gives a more subtle/soft and even bounce effect than regular white would, with pretty good success. It might help you get a little more lift in the face in addition to reducing the green.
  • Mark Suszko
    June 5, 2019 at 3:17 pm
    Black or gray cloth, ticks all the boxes for ease of use, economy, flexibility.
