Activity Forums Avid Media Composer AvidXproHD, DVCpro100 720P mixed with SD
  • AvidXproHD, DVCpro100 720P mixed with SD
    Posted by Dan L. on February 16, 2006 at 6:53 pm
    Hello all,
    A student of mine is embarking on a documentary production shot in DVCPROHD 720P 24. He needs to mix in various forms odf SD30i. Any suggestions for workflow. They are purchasing a XproHD setup for editing. Eventual destination is 35mm film.
    Does mojo downconvert 720p 23.976 to an SD monitor?
    Should the project be started and maintained as 720P23.976 as most of the footage is p2 dvcprohd.
    How then to import 30i SD clips?
    any help would be appreciated,
    best,
    Dan
    Joe Womble replied 20 years, 7 months ago 2 Members · 1 Reply
  • Joe Womble
    February 18, 2006 at 11:02 pm
    “Does mojo downconvert 720p 23.976 to an SD monitor?”
    No, not yet.
    “Should the project be started and maintained as 720P23.976 as most of the footage is p2 dvcprohd.”
    Yes, that is how you do it.
    “How then to import 30i SD clips?”
    https://www.24p.com/conversion.htm
    Regards,
    Cre8tive
