Activity Forums Avid Media Composer Avid/mac trouble with digitizing
  • Avid/mac trouble with digitizing
    Posted by Frozbulb on December 15, 2005 at 7:43 pm
    Would anyone know why I am having trouble with bringing footage into avaid. I have a mac g5 and dv xpress. The system quits as soon as I trun on the deck I use. I have tried dv cam decks and cameras, but it still shuts off when they are connected, and the program will not come up at all when they are connected at the start. I though it might be a security update but I have been having problems with it despite wiping out the OS and starting fresh.
    Frozbulb replied 20 years, 9 months ago 3 Members · 3 Replies
  • R. Hewitt
    December 16, 2005 at 10:27 am
    When you say the system quits, are you saying your G5 shuts down?
    There is a known problem with failing firewire ports on some G5 Macs and this may be the cause.
    The quickest and probably cheapest option is to by a firewire card to install in your Mac.
  • Dave Schweitzer
    December 19, 2005 at 6:47 am
    Try re-installing QuickTime. From what I’ve read this may help.
  • Frozbulb
    December 21, 2005 at 2:39 am
    Hey,
    that worked. i ended up going to the mac store and the genius there figued out that
    if avid and final cut wouldn’t work but the imovie did that it was the quicktime
    since imovie is the only one that doesn’t use quicktime. he went into receipts
    file and dumped the quictime updates and reinstalled it. the most current quicktime
    does not have the problems with import/capturing.
    thanks!
    ross
