Activity › Forums › Avid Media Composer › Avid Xpress Pro to Encore
Posted by James Mulvena on January 20, 2006 at 9:44 pmHas ANYONE had any success with this? If so can you tell me what settings you are using? I’m about ready to toss it!!
Thanks in advance.
Lucas Merino replied 20 years, 7 months ago 4 Members · 3 Replies -
Jon Zanone
January 20, 2006 at 11:03 pmExport out of the Avid as a QT Reference. We used PremierePro as an intermediate program to encode to mpeg. Then we discovered we could burn directly to DVD using PPro. Then we discovered a bug (for the life of me I can’t remember what it was), and we started using Sorenson and Reel DVD. All of our stuff is first play – no authoring necessary.
Jon
“So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
Del Amitri – “Make it Better” -
David Braswell
January 21, 2006 at 9:39 pmHi Debbie,
I responded to your previous inquiry about this. In case you missed it, you can read it at https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=45&postid=857686.
There was also another possible workflow mentioned in that thread. QT Reference files are viable. Basically, you’ll need to ensure that no unrendered space remains in your Avid sequence. Check that post unless you’ve tried it with no luck 🙁brazz
Lucas Merino
January 23, 2006 at 7:30 pmI have had very good success with exporting from XpressPro and authoring in Encore. I just finished a dvd where the main program was 24p material, and the bonus content was a mix (inluding some 16:9 and some 4:3).
I found that encoding mpeg2 in Sor. Squeeze only lead to possible problems, so mainly I exported Quicktime Ref. files (and sometimes self-contained quicktime) from Avid and encoded them directly in Encore (which uses the same encoder as Squeeze anyway).
Once everything was in Mpeg2 I authored as usual. What are you having problems with exactly?
