Activity Forums Avid Media Composer Avid Xpress Pro HD & Sony HVR-Z1U
  • Avid Xpress Pro HD & Sony HVR-Z1U
    Posted by Bill Reilly on November 4, 2005 at 4:55 am
    Im gonna be doing a project starting later this month using an Avid Xpress Pro HD and the camera will be a Sony HVR-Z1U. I was wondering if Ill be able to input this material 60i using firewire or will I need a deck? This will be my first HD project and I just wanna get as far ahead as I can. Thanks for any input
    Bill
    Jasenn Robertson replied 20 years, 10 months ago 3 Members · 2 Replies
  • Dan L.
    November 4, 2005 at 11:32 pm
    Should be able to input directly. Just make sure the setting on the camera is set to HDV, rather than downconvert to dv, I loaded some material from one of these cameras, and had trouble until I found that in camera setting.
    Best,
    Dan
  • Jasenn Robertson
    November 7, 2005 at 1:16 pm
    Also, when you launch Avid, you’ll have to create your project at 1080i/59.94 for NTSC, 1080i/50 for PAL. When outputing HDV back to tape, Avid actually makes a file and then copies that to your tape. It’s a little different than your typical digital cut, but has the same effect.
