Activity Forums Avid Media Composer Avid Xpress Pro Color Correction
  • Avid Xpress Pro Color Correction
    Posted by Gavin Gilmour on September 19, 2006 at 3:14 pm
    Hi there,
    Just a wee query – currently editing on Avid Xpress Pro and using the color correction facility…being used to Avid Adrenaline I expected to see my color correction happen in real time (otherwise what use is it?) but for some reason I can only see the effect take place when I play it or render it in Xpress Pro…is this a common experience with Pro or is there a setting I need to check???
    Cheers
    Tay
    Oakmozart replied 20 years ago 3 Members · 2 Replies
  • Michael Hancock
    September 19, 2006 at 5:09 pm
    “Render on the Fly” needs to be checked. It should solve your problem.
    Mike.
  • Oakmozart
    September 20, 2006 at 3:02 am
    Ditto. If that doesn’t fix the problem, reinstall the software. I once had the same problem, and had to fix it by reinstalling. After doing that, all was good.
    Ciao.
    It’s not the tool you use, it’s the end product that counts.
