Activity Forums Avid Media Composer Avid Xpress Pro Audio Problem
  • Avid Xpress Pro Audio Problem
    Posted by Joe Editor on July 8, 2006 at 3:53 am
    I have an Avid Xpress Pro with Mojo on a G5 Mac and I started having audio problems last week. Basically, I cannot hear output audio when the mojo is active. I originally thought it was a problem with the RCA cables out of the mojo to the main speakers, but I don’t even see the internal VU meter reading anything (just like when you turn off all the speakers in the audio channels).
    However, when I disable mojo, I can see the audio levels and I can hear output audio to the computer speakers.
    Please help!
    Joe
    Vincenzogreen replied 20 years, 1 month ago 4 Members · 5 Replies
  • Dan O’brien
    July 9, 2006 at 3:06 pm
    I know it sounds wierd, but have you added any firewire connections to the G5 recently? On my G5, I have to re-arrange my firewire connections to fix these kinds of glitches. Just a thought.
  • Geraint Pari huws
    July 9, 2006 at 5:34 pm
    is the project smaple rate the same as the media?
  • Joe Editor
    July 15, 2006 at 4:54 am
    I have added 2 drives, but I unplugged them and the problem persists….could it be because I added Final Cut? Can I have both systems in the same computer?
  • Joe Editor
    July 15, 2006 at 4:55 am
    Yes, the project audio rate is the same ….48……..could it be because you can’t have both FCP and Avid on the same computer?
  • Vincenzogreen
    July 22, 2006 at 9:51 pm
    re: having both Xpress and FCP on the same system – I have used several machines that have not had a problem with this. On the other hand Avid and Premiere cannot co-exist under the same Windows OS due to a system file that both fight over…
