Activity Forums Avid Media Composer AVID Xpress DV to After FX
  • AVID Xpress DV to After FX
    Posted by Christopher Dutton on October 14, 2005 at 5:02 pm
    Hi. I would like to export files from AVID Xpress DV 3.5.4 to After FX 6.0. on another PC, do some compositing there, and then export the After FX files back to AVID. What are the best export settings for both AVID and After FX?
    Forgive me if this has been posted before. I searched but didn’t quite find the information I was looking for.
    Thanks a million!
    Wes Plate replied 20 years, 10 months ago 4 Members · 14 Replies
  • 14 Replies
  • Wes Plate
    October 14, 2005 at 7:53 pm
    If you need your Avid timeline rebuilt in AE, take a look at Automatic Duck’s Pro Import AE.
    If you’re just dealing with single clips, export out of Xpress DV as a QuickTime Reference movie.
    — Wes Plate
    Automatic Duck
  • Christopher Dutton
    October 14, 2005 at 7:57 pm
    Hey thanks.
    And yes, I am exporting individual files. Can I use Quicktime Reference files even if I’m using a different PC for After FX compositing? In other words, I have to physically transport files from my work Avid to my home PC to work in After FX.
  • Wes Plate
    October 14, 2005 at 8:02 pm
    In that case export using the “Fast-Export QuickTime” option.
    — Wes Plate
    Automatic Duck
    October 14, 2005 at 8:04 pm
    Great, I’ll try that next. Thanks!!
  • Tae
    October 17, 2005 at 1:57 pm
    Forgive me, but why on earth would you want to export Avid titles to After Effects?
    October 17, 2005 at 2:35 pm
    Actually, I mis-wrote… What I really would like to do is export AVID video and composite just titles over that video in After FX. Then, re-import back into AVID. The AVID title tool has always been pretty weak.
  • Tae
    October 17, 2005 at 3:00 pm
    Ahhh… that makes MUCH more sense.
    I would export as a QT, Animation codec, no compression. Looks great.
  • Dave Schweitzer
    October 18, 2005 at 4:37 am
    I would export from Avid to a self-contained Quicktime, Same as Source, 601 with Avid codec checked.
    Do fun things in AE (you may need to interpret the file as lower field first if 6.0 doesn’t automatically) and export as Animation Lower field first. This will give your text a better chance of looking good – especially if the font is thin.
    October 18, 2005 at 10:03 pm
    Cool. Thanks. I’ll try that, too.
    Hey, here’s another question: Let’s say I want to do the opposite; create titles in After FX, without having video from AVID. What’s the best way to export titles with alpha channels so that I can cleanly, simply key them in AVID?
    (I’ve already tried a few tests, rendering titles as Quicktime animations, RGB + alpha, but the titles look crappy. I’ve seen better and I’m wondering how to get there.)
    Thanks again for any and all help.
  • Dave Schweitzer
    October 18, 2005 at 11:39 pm
    If I’m creating content in AE for Avid, I do all my work in a 720×540 Sq pixel comp (so it looks exactly like what it’ll look like on a TV) then before rendering create a new comp at D1 size (720×486) and drop my work comp in there, hitting alt-option-f (mac) to autofit the 540 layer to the 486 comp. Then if filesize is not an issue, I’ll render to Animation w/alpha UNMATTED and import that into Avid. If space is tight, then I’ll render an Avid 2:1 of the full color comp and also render out an ALPHA only, using Avid’s Matte Key filter to do the composite in the Avid Sequence.
    This combo should give you excellent results.
