Activity › Forums › Avid Media Composer › AVID XDCAM import error
  • AVID XDCAM import error
    Posted by Tom Nelson on January 21, 2010 at 9:09 pm
    I’m at an offsite meeting working on location on an Avid Media Composer. We’re capturing everything onto dual-layer XDCAM discs and bringing them into the system via a PDW-U1 XDCAM drive. It has been going smoothly up until now – I attempt to import a 26 GB file and at the very end of the import it freezes avid and I get an error message about some MiniDump Filename. I will post the exact message when I get it again, but it probably won’t be for a while and this is an URGENT issue. Thanks in advance for the assistance.
    Specs
    MC 4.0.2.30
    HP Z800
    Intel Zeon 2.93 x2
    6 GB Ram
    Tom Nelson replied 16 years, 8 months ago 1 Member · 1 Reply
  • Tom Nelson
    January 22, 2010 at 8:51 pm
    Here is a paste from the error message I received:
    ________ Exception Report ________________________
    Exception Code: C0000005 ACCESS_VIOLATION
    Fault Module: 01:0038931E C:\Program Files (x86)\Avid\Avid Media Composer\ameLibrary.dll
    Fault Address: 0314A31E XDCAMHDHiresVideoImportReader::createIndexTable+FE
    ________ Stack Dump _________________________________________
    0314A31E 2F198000 XDCAMHDHiresVideoImportReader::createIndexTable+FE
    AVID SYSTEM DUMP – Fri Jan 22 15:39:37 2010
    ________ Memory ________________________________________________________
    numPtrs: 168031
    numHdls: 08991
    totalPtr: 0x021a665f (35284575)
    totalHdl: 0x000965ce (615886)
    ________ Current Program Stack _________________________________________
    773F039D 0017D1F4 ZwWaitForSingleObject+15
    764511D8 0017D208 WaitForSingleObject+12
    60399852 0017D21C PSPrintStack+82
    6031471B 0017D2AC DmpDump+9B
    60314C4B 0017D564 DmpDumpToFile+3CB
    60319EA0 0017DB1C AvRgn::InternalHRGN+EF0
    6031AFA8 0017DB84 AvRgn::InternalHRGN+1FF8
    7C359C97 0017DBCC _CxxLongjmpUnwind+EA
    7C359629 0017DBFC _CxxExceptionFilter+1C4
    7C3598AD 0017DC54 _CxxExceptionFilter+448
    7C35994A 0017DC84 _CxxExceptionFilter+4E5
    7C359B9D 0017DCBC _CxxFrameHandler+26
    773F3099 0017DCE0 RtlRaiseStatus+B4
    773F306B 0017DD90 RtlRaiseStatus+86
    773F2EFF 0017DD94 KiUserExceptionDispatcher+F
    0017DDA8 773F2EFF Symbol Not Found – Error 0000007E(00000126)
    006A595B 773F2F03 AApplicationBase::operator=+29D5BB
    DA63E851 773F2F07 Symbol Not Found – Error 0000007E(00000126)
    0BEBFFFF DA63E851 Symbol Not Found – Error 0000007E(00000126)
    ________ System Configuration __________________________________________
    System software: Windows NT Version 6.0 Build 6001 Service Pack 1
    Processor type: Pentium PC
    Physical Memory: 4095 MBytes; Virtual Memory: 4095 MBytes
    User name: default
    Application info: Hitchcock_4.0.2_Patches_R30
    ________ Processes Currently Running ___________________________________
    ________ WindowList ____________________________________________________
    Hidden Rect: 596, 170, 613, 391
    Hidden Rect: 596, 391, 613, 408
    Internet Explorer Hidden Rect: 237, 170, 30407, 408
    Hidden Rect: 237, 170, 30407, 170
    ________ Binary Modules Loaded _________________________________________
    ________ Device Drivers Loaded _________________________________________
    Tom Nelson
    Videographer/Editor
    Essex Television Group
