Activity › Forums › Avid Media Composer › Avid Won’t Transcode Atomos Samurai Footage
  • Avid Won’t Transcode Atomos Samurai Footage
    Posted by Matthew Sonnenfeld on April 12, 2013 at 2:34 pm
    We have Samurai footage that was shot in ProRes and while Avid will link to it with AMA, it will not transcode the media to make proxy files. It takes several hours to transcode only to reach an error message at the end.
    Does anyone know what may be the problem?
    Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
    2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 16GB RAM
    AJA IoXT
    Adobe Production Premium CS6, Avid Symphony 6, Final Cut Pro Studio 3
    The College of William and Mary
    Chris Harlan replied 13 years, 5 months ago 4 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    April 12, 2013 at 3:37 pm
    What’s the error message?
    Shane
    Little Frog Post
  • Matthew Sonnenfeld
    April 12, 2013 at 3:49 pm
    Attached is a screen grab of the error message;
    AJA IoXT
  • Shane Ross
    April 12, 2013 at 3:53 pm
    You might have to skip AMA on this and just do a basic import:
    https://community.avid.com/forums/p/86225/542420.aspx
    Shane
    Little Frog Post
  • Michael Phillips
    Are you transcoding to DNxHD, or do you want to keep it as ProRes and just rewrap as MXF? How long are the clips? What’s the error message?
    Try:
    Subclipping in half before the transcode and see if you get the same error message
    Fast import will keep it as ProRes – does that give a message?
    Michael
    April 12, 2013 at 5:45 pm
    Unfortunately I came to the project late and it’s actually already been onlined using SxS media that was shot simultaneously but I’m trying to back track to see what the problem could have been so that I can hopefully prevent it from happening again. The importing instead of AMA is an interesting suggestion. I will see if we can go back to the Samurai masters and run a test. The shots are very short for the most part so I don’t think length of them would be the problem.
    AJA IoXT
    April 12, 2013 at 5:46 pm
    Also yes, we were transcoding to DNx36
    AJA IoXT
  • Chris Harlan
    April 13, 2013 at 6:02 am
    Maybe a bug in your metadata?
    I’ve actually run into a problem similar to this a couple of times while rewrapping ProResHQ !080@50i to MXF. I’m curious–when you bring in the AMA file does it seem like it might be a couple of frames out of sync even though TC matches across the channels? The files would load and play fine in other NLEs, btw.
    What I ended up deciding is that there was some sort of metadata mismatch that was causing the hang, probably from some odd setting at the post house where the files were generated.
    I solved my problem by running my ProRes files through Compressor, straight across, keeping all settings the same and just re-compressing. Worked beautifully. Didn’t like the added time, but it ironed out the file.
  • Chris Harlan
    April 23, 2013 at 5:25 am
    I’m curious. Did you ever get to the bottom of this?
