Activity Forums Avid Media Composer Avid won’t import 44.1k wav files: araw codec?
  • Avid won’t import 44.1k wav files: araw codec?
    Posted by Chris Dukes on July 28, 2007 at 10:18 pm
    I recorded the wav files with a Tascam HD-P2 at 44.1k but Avid doesn’t recognize the file type. It will recognize the wav files I recorded on the same machine at 48k. The problem is that the only thing I have that recognizes the 44.1k files is VLC otherwise I would just convert them with iTunes or FCP/Compressor. Any suggestions?
    Mech
    Chris Dukes replied 19 years, 1 month ago 3 Members · 4 Replies
  • Jon Zanone
    July 29, 2007 at 1:53 am
    You can transcode the files within Avid. Right click on the file and follow the dialog box. Alternately, you can select the entire project as 44.1 (setting>audio project>44.1).
    HTH,
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Chris Dukes
    July 29, 2007 at 7:15 am
    So if I change the project settings to 44.1k then import them, then export them as 48k, then change the settings back to 48k, I should be ok?
    Mech
  • Jhones
    July 29, 2007 at 9:22 pm
    you can stay where u r and just transcode it on the spot to your project rating
    ~Jhones~
  • Chris Dukes
    August 3, 2007 at 12:16 am
    So how can I transcode them?
    Mech
