Activity Forums Avid Media Composer avid v5.0.3 crashes when exporting
  • avid v5.0.3 crashes when exporting
    Posted by Ben Stark on September 14, 2011 at 1:52 pm
    Hi All,
    I’m running avid 5.0.3 on a mac and every time i try to export my sequence (using avid codec same as source) it runs through the whole 90′ timeline then i get the spinning wheel of doom, and its fallen over.
    I’ve tried cutting sequence in half to see if i can narrow the fault to a corrupt clip but the same thing happens.
    Anyone any ideas?
    also i have the upgrade to v5.5, that is a lot more stable but am reluctant to upgrade near the end of a project, have others had problems or been fine with the upgrade?
    be great to hear your thoughts, thanks
    b
    Daniel Huber replied 14 years, 10 months ago 2 Members · 1 Reply
  • Daniel Huber
    October 14, 2011 at 4:51 am
    How have you imported this into the avid?
    I would also make sure you have the correct codecs package installed on that machine. If you still have the Avid installer Disc or file, just go into the installers folder and install the Avid Codecs PE and LE. Then try again. You might want to try a small chunk first. I would also try to save it local instead of to an external drive.
