Activity Forums Sony Cameras Avid to Xdcam backup
  • Avid to Xdcam backup
    Posted by Mick Reilly on March 30, 2014 at 5:56 pm
    Avid on PC
    I want to back up some clips or sequences to xdcam disc, but I want to maintain the clip or sequence names.
    Is this possible?, Would appreciate any help on this
    Thank you
    Ian Cook replied 12 years, 5 months ago 2 Members · 1 Reply
  • Ian Cook
    March 31, 2014 at 2:40 pm
    The original clips can be backed up in the CLIP folder and the Avid library clips and other non-XDCAM files (the op-atom files from Avid Media Files/MXF/#) can be backed up in the User Data folder. if what you need is just a matter of backing up XDCAM file with unique file names, set Free Naming on the device to ON. if you are using the U1/U2 drive this setting is in the drive utility application. On the decks and cameras it’s in the operational menu.
