Activity › Forums › Avid Media Composer › Avid to Resolve
Avid to Resolve
Posted by Eric Santiago on March 23, 2012 at 12:59 amCan I export an old XDCAM laden project from Avid MC to Resolve?
I have to wait till next Monday to try (studio down for repairs).
Ive done R3D>AMA>AvidMC>Resolve but not from older projects.Eric Santiago replied 14 years, 5 months ago 5 Members · 6 Replies -
Pat Horridge
March 23, 2012 at 8:07 amNo gotten round to testin that yet.
Mainly transcode to DMX 185 in Avid first for most stuff unless it’s Red and I need to go back to the original source media.
Have you checked the Resolve codec support list? That has all the supported codecs on it and if XDCAM is there your in luck.Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US -
Juan Salvo
March 23, 2012 at 9:26 pmXdcam is only supported in an mov container. To use AAF into resolve you need to transcode to DNxHD.
Eric Santiago
March 25, 2012 at 12:33 amSorry I didnt clarify my workflow.
The files are all DNxHD due to import from XDCAM.
Im just wondering (out loud) if its a simple export from Avid into Resolve then back.
Trying to create one killer workstation at work with Avid and Resolve all on the same box. -
Mike Jeffs
March 25, 2012 at 7:19 pmWe have been playing with this workflow for a while, but still trying too work out all the quinks
What we have done is XDcam media AMA linked in.
Finished the Edit and transcoded the sequence to DnXHD.
Exported a AAF of that sequence.
Opened in resolve and color graded.
Then in Resolve Render the media into the Avid Media MXF Folder.
Export out a New AAF.
Then in the Avid media folder you have to delete (or move) the.MDB files, so when avid opens it can rebuild the database with the new color graded media there.
In Avid import the AAF and volia there your new sequence all color graded.
WE have found a couple of quirks depending on the length of the sequence if it really long 1 hr+ its best to export smaller chunks to bring into resolve as sometimes the avid wigs out and doesn’t bring in all of the graded render files.
also if you are working in multi frame rate sequence make sure that all of the media in the “wrong” frame rate is rended into the “right” frame rate as resolve can’t work in a mulit frame rates.
Mike Jeffs
Video Coordinator
BYU-Idaho -
C. Ryan stemple
March 26, 2012 at 8:31 amHey there, Eric.
If you’ve already transcoded to DNxHD, then this round trip workflow might work well for you:
https://www.youtube.com/watch?v=60vSLLekX6Q
It doesn’t hurt that the guy giving the tutorial has some pretty funny dry humor. 😛
Hope this helps!
Carl Ryan Stemple
Color | Edit | VFX
digitalbarbershop.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Eric Santiago
March 27, 2012 at 1:01 amThanks Carl, looks great! now hoping no hiccups in the Mac side 😉
Ill try this tomorrow at work.
Again thanks.
