Activity Forums Apple Final Cut Pro Legacy AVID to Pro Tools & FCP
  • AVID to Pro Tools & FCP
    Posted by Liam Stephens on February 8, 2006 at 7:06 pm
    Hi
    After exporting picture to FCP for color correction and OMFs to Pro tools for mixing we are having problems. When the audio is mixed we are bouncing to an aiff file then having issues syncing with picture in FCP. When i bring the same bounced aiff into the Avid the sync is fine. So, if i am working in a 24p NTSC, 35mm, 4 Perf within Avid Express Pro what would be the equivalent sequence in FCP? The picture was exported using None Compression and at the current frame rate.
    any ideas?
    Liam
    Liam Stephens replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
