Activity Forums Adobe Premiere Pro AVID to Premiere no sound
  • AVID to Premiere no sound
    Posted by Ben Allan on May 3, 2017 at 1:05 am
    So I have been trying to get a project I was given from AVID to premiere.
    It’s 7 minutes long. There appears to be different types of audio in the project and I believe most of the clips are sub clips.
    I tried just exporting an AAF but no luck. It either crashes Premiere or errors to import.
    I have tried a workflow i found on these forums where i import the AAF back into it’s self. Put it into Resolve then exported an XML. Which almost works but I fail to get any of the audio tracks. I did make sure audio tracks were selected when exporting the AAF. I have yet to link it but that should work…
    Anyone got any ideas for this i would really appreciate it,
    Kind Regards,
    Ben.
    Trevor Asquerthian replied 9 years, 4 months ago 2 Members · 1 Reply
  • Trevor Asquerthian
    May 3, 2017 at 7:42 am
    I tried it on a very simple sequence – in Avid I made sure that the AAF was set to Consolidate video and audio, to a separate folder.
    Came into Resolve 14b OK.
    PP 2017.1 reported a ‘serious error’ and quit.
    PP 2017.0.2 imported OK – it seems to create nested sequences to marry up OP-Atom (i.e. seperate) Video and Audio – I can see how that might cause problems if the audio has L or J cuts or is non-synchronous.
    I’m pretty sure that PP and Resolve don’t handle embedded media.
    No time for further investigation at the moment but will try and look into it a bit further if I get the chance.
