Activity › Forums › Avid Media Composer › Avid To Premier workflow with AMA
  • Avid To Premier workflow with AMA
    Posted by Mark Baird on October 8, 2014 at 3:40 pm
    A client sent me a disk with his P2 images on it. I need to AMA these in, do a multicam edit, then export a file that he can take into premier 6, polish the edit, add graphics, etc.
    So far everything works except I cannot export an AAF of the time line to send him because it says I can’t do that with AMA files??
    However, if I ‘import the files’ that makes them DNxHD files and he won’t be able to use the AAF to link back to the original P2 files… What am I missing?
    MB
    Michael Phillips replied 11 years, 11 months ago 2 Members · 2 Replies
  • Mark Baird
    October 8, 2014 at 3:44 pm
    Never mind… missed that the AAF edit protocol button was not checked.
    Works now
  • Michael Phillips
    October 8, 2014 at 9:32 pm
    As you discovered, earlier versions of MC needed Edit Protocol active. I believe that went away in v7 and is no longer needed for AMA linked files.
    Michael
