Activity Forums Apple Final Cut Pro Legacy AVID to FCP sound relink?
  • AVID to FCP sound relink?
    Posted by Laura Creecy on August 13, 2010 at 6:02 pm
    Project:
    offline in AVID MC4
    online in FCP7 & AE
    picture is fine, but I am having problems with the sound… I AutoDuck a AAF file into FCP and the clips for sound come up on the timeline fine, but somewhere in the process they’ve lost the link to the original file name. I can do a reconnect to media for picture and it will link back correctly no problem, but sound does not.
    I wasn’t the asst. so I dont know the exact process but I speculate in the Avid the sound was grouped and subclipped to sync with the picture and it is in this process that it is losing its link to the original file name.
    Is there someway in AVID to ungroup or do something to the sound so that it links back to its original file name? I dont want to have to manually reconnect every clip. We have HOURS of footage.
    The original file name is -T08.wav
    its looking for file in FCP reconnect -/8.new10
    and the clip in the bin is named 01/1 Ditka.new.06 which I assume is part of the renaming when grouping – the Reel column in the bin says -T08A.WAV:2010-06:21 which is the original file and folder
    Michael Gissing replied 16 years, 1 month ago 3 Members · 2 Replies
  • Micah Haun
    August 13, 2010 at 6:48 pm
    Doesn’t automatic duck let you bring in media as well? Particularly since you’re dealing with uncompressed audio, you aren’t going to lose quality by bringing it in this way.
    if this is not an option, here is how you give your audio back its original name:
    In avid, go to the bin with your source audio. Scroll over to the “Tape ID” column. It should have your source file name.
    If Tape ID does not have your source file name. Add a new heading and call it something like “Media Name”. Assuming your clips are still named after their source files, duplicate the “Name” field (cmd D) over to your new “Media Name” column.
    Create a new bin in your project and duplicate the sequence to it. Open this sequence and delete all video tracks. Decompose the sequence, un-check “offline only”, and set it to imported and captured clips. I would also un-check the option to make a new sequence, but it won’t hurt anything. Now reverse the process. Duplicate the “Tape ID” or “Media Name” column back to the “Name” column. Your timeline will now have audio with the correct clip names.
  • Michael Gissing
    August 13, 2010 at 10:57 pm
    Export an audio OMF or AAF directly from the AVID to load into your sound post machine. There is nothing to gain by bringing anything in FCP except a guide mix track for onlining.
