Activity Forums Apple Final Cut Pro Legacy Avid to FCP…. couple of problems!
  • Avid to FCP…. couple of problems!
    Posted by Jamie Worsfold on January 9, 2008 at 10:07 am
    Hi
    I’m currently onlining a couple of projects on FCP that were cut on a Media Composer.
    Automatic Duck was used for translating it across – all well and good as usual apart from a couple of oddities that need sorting:
    The director loves his speed effects and there are a few variable speed shots from the Avid which didn’t translate properly. Personally speaking I’ve never had much joy with the variable speed in FCP anyway, and usually just end up putting cuts in and using constant speed within those cuts. But has anyone else had any issues translating these variable speeds from Avid to FCP? And any luck in solving them?
    Secondly, there were some morphing effects added in Avid which didn’t translate at all. Which I’m not surprised about, as FCP obviously doesn’t have a morphing plugin. Any ideas about how to solve it?
    Thanks everyone!
    Peter Dewit replied 18 years, 8 months ago 5 Members · 6 Replies
  • Bouncing Account needs new email address
    January 9, 2008 at 10:15 am
  • Mark Raudonis
    January 9, 2008 at 3:13 pm
    For the speed FX: You’re hosed!
    Recreate by hand. One clue: if you look at the key frames you’ll often see a “random” key frame” which sends makes your new ramp totally whacked. Deleting that key frame often puts you back to the original intent.
    If you’d started in FCP, you would open BOTH your off-line and on-line sequence to observe which key frame was random. But, you’re coming from AVID (not a good idea) and therefore, you’re toast. Sorry.
    Mark
  • Jamie Worsfold
    January 9, 2008 at 3:33 pm
    As I thought on both accounts…!
    Cheers guys
    jamie@jambonfilms.co.uk
    Jambon Films
  • Walter Biscardi
    January 9, 2008 at 3:39 pm
    [JamieWorsfold] “The director loves his speed effects and there are a few variable speed shots from the Avid which didn’t translate properly”
    If the Director gives you an AAF they should translate ok. With OMF you’ll only see slo motion in FCP. With AAF’s I’ve found that about 80% of the speed changes in Avid come over perfectly.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Jamie Worsfold
    January 9, 2008 at 3:55 pm
    It was an OMF it would appear. The post facility I’m in had done the conform before I came in, so I should have just been doing a straight checking and grading. But these little things have popped up…
    To be honest, it was done at such a low res on the Avid that they probably wouldn’t have noticed the problems I’m getting anyway – mainly jerkiness and some nasty field problems even once I’ve cut it and sped it up manually. So it may actually be down to the motion in the shot coupled with the speed…
    I shall get to the bottom of it 😉
    Jambon Films
  • Peter Dewit
    January 9, 2008 at 8:23 pm
    In automatic duck are you translating the OMF with or without media?
