Activity › Forums › Adobe Encore DVD › AVID to Encore – Missing video in MOV file
Posted by Terri Bibby on February 14, 2008 at 11:53 pmI am trying to create a DVD using Adobe Encore. The editing was done in AVID and was exported as an MOV file. When I play the MOV file it looks fine. When I import it into Encore – there is no video (black screen), audio is fine.
Any ideas?
TerriMelinda Bateman replied 16 years, 9 months ago 4 Members · 7 Replies -
Jeff Bellune
February 15, 2008 at 1:13 amWhat version of Encore?
What codec did you use in Avid to export to Quicktime?
Is it a self-contained .mov file, or a reference QT?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Jeff Bellune
February 15, 2008 at 2:30 amHi Terri,
Those are both good answers. Do you know what codec was used? If the codec in the .mov file isn’t to Encore’s liking, then you can end up with problems like the one you’re having.
-Jeff
Terri Bibby
February 15, 2008 at 4:54 amI know what all the settings were for creating the .mov file in AVID, but don’t know what the codec is/was. Basically, the options are to create a QT mov or QT reference, etc. and then the settings for quality, etc.
Terri
Jeff Bellune
February 15, 2008 at 1:14 pmMOV files are like AVI files – they are just format wrappers for different codecs. For example, an AVI file can be DivX, DV, HuffYUV, Cinepak, etc. The choices for MOV files are different, but they are available, including Animation, Sorenson, H.264, MJPEG, etc.
The choice of codec is significant.
Gary Seamans
April 10, 2008 at 2:57 pmI have been having similar problems importing QT Ref video created on the AVID — sometimes video, sometimes no video. But yesterday I began getting a “Quicktime and/or appropriate codec do not appear to be installed” message; this was for both Quicktime and Quicktime reference videos. Which program needs the codec? The AVID for exporting or the Encore DVD for importing? And where can I find it?
Also, I tried to import AVIs, but I get a message stating that the decoders for that media are not available on my system.
Thanks in advance.
Melinda Bateman
December 8, 2009 at 4:40 amHas anyone posted the answer to this question? I’m having the same problem from FCP to Encore, and I’m not sure if the problem is from the export end or import end. I’m using FCP 6.0.2 and CS3 Encore. I get “Quicktime and/or the appropriate codec do not appear to be installed.
