Activity › Forums › Avid Media Composer › Avid timeline settings….please assist!
  • Avid timeline settings….please assist!
    Posted by Casey Swircz on October 25, 2011 at 3:25 pm
    How can I change the timeline fps in an avid project. i know you have to set it up when you start a new project but can you change the frame of your timeine while you are in the project and how????
    Casey
    Shane Ross replied 14 years, 10 months ago 6 Members · 9 Replies
  • 9 Replies
  • Neil Goodman
    October 25, 2011 at 4:03 pm
    i dont think so. Best bet would be to make an ew project at the correct frame rate, and then open the bins from the other projects into thhe new one.
    Neil Goodman: Editor of New Media Production – NBC/Universal
  • Shane Ross
    October 25, 2011 at 5:40 pm
    Neil is right. Make a project with the settings you want. And then, on the FINDER level, COPY the bins from the old project to the new one. Then open the bin in the new project. When you click on the sequence to open it, it will say “I need to change the frame rate to match the project settings.” Click OK to this. And then BOOM, the timecode changes. All the clips have green dots (if their frame rates differ from the current one). And you are good to go.
    Shane
  • John Pale
    October 25, 2011 at 5:41 pm
    You can’t.
    You need to create a new project . You can move bins containing footage at any frame rate into that project. When that footage is placed in a timeline, a Motion Adapter will be applied to convert the footage to the project frame rate.
    (in version 5.x anyway)
  • Paul Del vecchio
    October 27, 2011 at 4:46 am
    You are able to change the timeline settings, but it’s kinda hidden. You can right click on the timeline in the bin and choose MODIFY, then fromt he dropdown menu choose SET FORMAT and you can choose from a whole bunch of settings.
    The only problem is that when you try to open that new sequence, it gives you an error saying, “The sequence frame rate does not match the project frame rate. Do you want to load a copy of this sequence that has been modified to match the project’s play rate?”
    Then you get to pick “yes” or “no.”
    Maybe if you start a new project and open the bin containing the new sequence, you can actually open it up but I haven’t checked that. You should be able to because otherwise it would be a pointless feature.
    Paul Del Vecchio – Director
    https://www.triple-e-productions.net
    https://www.pauldv.net
  • Casey Swircz
    October 27, 2011 at 2:53 pm
    Great information! Thank you so much!
    Casey
  • Dawn Rider
    December 1, 2011 at 9:46 pm
    Hi there,
    We’re working on Avid MC 5.5.2, and our project is 23.976p NTSC. Our timeline timecode windows are showing 30 NDF timecode, however.
    Does anyone know how to fix this?
    Dawn
  • Shane Ross
    December 1, 2011 at 9:53 pm
    Could be that NTSC SD doesn’t really have a 23.98 timebase. That’s HD territory. Does the code skip frame numbers? I guessing it does.
    Shane
    Little Frog Post
  • Dawn Rider
    December 1, 2011 at 10:29 pm
    Yes, you are right. The timecode is skipping frames. I guess there is no way to force the sequence timecode to run continuously at 24fps?
  • Shane Ross
    December 1, 2011 at 10:32 pm
    Not really. Because NTSC is a 30 frame format. Only HD and Film can truly be 24fps.
    Where did your footage come from?
    Shane
    Little Frog Post
