Activity › Forums › Avid Media Composer › Avid stuttering timeline issue, please assist!
  • Avid stuttering timeline issue, please assist!
    Posted by Jordan Freese on June 11, 2010 at 1:50 pm
    Hi all. I’m running out of things to try so hopefully someone has some ideas. We are using Avid 3.1.3 on and hp xw8200 and a mediadock u320 scsi raid 0 array with 12 146gb drives (1.6tb total). Amytime more than 1 stream of HD footage is played in the timeline (even simple dissolve effect) the timeline stutters as if there is a bandwidth bottleneck or something. This what I’ve tried so far:
    Replaced Ram, replaced video card, tried different os’s – winxp 32, win7 64, win vista 64, swapped out the mediadock chassis and cables. Swapped out all disks (actually the first time I swapped out the disks it worked ok, then when I swapped the old set in to pull data an put the new array in again, the problem arose again – weird). I’m thinking it might be the onboard dual channel scsi controller on the motherboard at this moment but any ideas would be greatly appreciated. Thanks everyone.
    Jordan Freese replied 16 years, 3 months ago 2 Members · 2 Replies
