Activity Forums Avid Media Composer Avid sequence to YouTube
  • Avid sequence to YouTube
    Posted by Peter Ovens on January 11, 2010 at 8:59 am
    How does one go about putting a 50 second sequence on a you tube account, I have created the account for our local hockey team and wish to convert the avid sequence of hiltes. how do I convert to a file that you tube uses like .wmv
    thanks Peter
    Peter Ovens
    Grinner Hester replied 16 years, 8 months ago 3 Members · 2 Replies
  • David Braswell
    January 11, 2010 at 2:39 pm
    We’ve had great success using Sorenson Squeeze to encode. Upload size permitting, I generally create an original size and aspect ratio reference movie. I use H.264 with a bitrate around 6Mb/s and AAC audio at 320 kb/s. I’d use VBR encoding for a piece as short as yours. You should experiment with the quality level based on the complexity of your video.
  • Grinner Hester
    January 11, 2010 at 3:41 pm
    mix it down first (avid has an interlacing bug when sending to sorenson, otherwise) then export a QT reference. Import that into sorenson squeeze and encode a wmv at 500kbs. Anything over 320X240 will be fine as youtube will then make it their native rez.
    Alternatively, you can export a wmv out of Avid but it’s slower and with less handles than sorenson squeeze.
