Activity › Forums › Compression Techniques › Avid Sequence to DVD using Compressor
  • Avid Sequence to DVD using Compressor
    Posted by Alex Mermelstein on August 9, 2011 at 3:34 pm
    I work with Avid DNX files, but very often clients want DVD dailies. From Avid, I export a QT reference movie same as source. I then bring the .mov into a FCP sequence so I can add a slate and B&T. Then, I send the sequence to Compressor (I use compressor because sometimes clients want security burns on the DVD and compressor is great at doing that.)
    This encoding process takes about 2 hours for a 60-min reel. My question is what settings can I use to give good quality, but also reduce the encoding time? I currently have it set to One-Pass VBR 6.0-7.0 The original is 1920x1080psf.
    Also, if anyone knows a more efficient way, please let me know, but do not suggest Episode. I’ve tried it and it doesn’t let me do things that compressor allows.
    Jeff Greenberg replied 15 years, 1 month ago 2 Members · 1 Reply
  • Jeff Greenberg
    August 14, 2011 at 8:53 pm
    Why aren’t you adding slate/B&T inside of Media composer?
    You likely could go in at CBR at the same data rate and have a decent looking file.
    Last, Compressor is the only tool that will directly make a DVD; Episode and Squeeze can certainly do decent (and possibly better) compression for MPEG2. It’s not that Compressor sucks, it’s just that their MPEG2 algorithm could be better.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
