Activity Forums Avid Media Composer Avid ScriptSync questions
  • Avid ScriptSync questions
    Posted by Brian Wessel on July 29, 2011 at 3:06 am
    This is for any ScriptSync experts out there:
    * Is there a way to modify the size of the frame that is in the script after it has been imported?
    * Is there a way to insert dialogue without going back to Final Draft? (ex: there are some extra lines the actors improvised)
    Thanks a lot!
    – Brian
    Michael Phillips replied 15 years, 1 month ago 3 Members · 2 Replies
  • Job Ter burg
    July 29, 2011 at 7:03 am
    I think you can change frame size with CMD-K / CMD-L (Mac) or CTRL-K / CTRL-L (PC). Not sure, but give it a try.
    You can’t edit text, AFAIK.
  • Michael Phillips
    July 29, 2011 at 11:53 am
    Same commands as enlarging frames in bin work in ScriptSync. You cannot directly edit a script, but can edit line(s) by copy/pasting in and out of ScriptSync to a text editor.
    Michael
    Michael Phillips
