Activity Forums Avid Media Composer Avid safe area
  • Avid safe area
    Posted by John Neer on October 19, 2011 at 1:13 pm
    Is there a way to change the color of the safe area boxes outline from white to black. I have a project with mostly white background and it is hard to work within the safe area zone when adding text….or most any pic in pics.
    Michael Hancock replied 14 years, 11 months ago 2 Members · 3 Replies
  • Michael Hancock
    October 19, 2011 at 1:16 pm
    There’s a setting you can change but I can’t remember where it is and don’t have access to an Avid right now. EDIT: Look for the Grid setting. I think it’s in there.
    Poke around your settings and you’ll can find them. Once you find them you’ll see that you can also set them to be 4:3 in a 16:9 frame, change the percent of title safe, turn grids on and off – lots of fun stuff, including changing the color of them.
    Michael Hancock
    Editor
  • John Neer
    October 19, 2011 at 1:24 pm
    How simple can it be? Yes it was in the Grid settings…..thanks my friend for such a fast reply. Have a great day.
  • Michael Hancock
    October 19, 2011 at 1:28 pm
    Awesome. Glad I remembered the setting right and it worked out for you!
    Another tip – select the Grid setting in your settings panel and hit Ctrl+D (PC) or CMD+D (Mac) and duplicate it, then change the duplicate to match the project. That way you can just switch over to your settings panel and check the other one when you need to go back to the standard white overlay, or save a separate 4:3 in 16:9, etc…
    Michael Hancock
    Editor
