Activity Forums Avid Media Composer AVID resolutions
  • AVID resolutions
    Posted by Diego Araujo on March 4, 2008 at 9:20 pm
    We have this footage that was shot on a Panasonic HVX-200 set to 16:9 SD.
    Using Avid Adrenaline, I digitized one particular clip using three different resolutions: 10:1 OMF, 1:1 OMF and DV 25 411 OMF.
    I am looking, side to side, at the 3 different resolutions (on a professional-grade Sony monitor).
    I find it impossible to see any noticeable differences in the picture quality of the three different resolutions.
    Does it have to do with a camera compression, is it a playback thing… any theories? I’m just wondering…
    After all, the difference in disk space is huge.
    Diego
    Diego Araujo replied 18 years, 6 months ago 2 Members · 4 Replies
  • Michael Todd
    March 4, 2008 at 11:05 pm
    I can only guess that you shot this in DV format which is DV25 native compression. Which means your 1:1 capture and your DV25 capture would look almost indistinguishable. As for the 10:1, make sure you viewing it as 16:9 not 4:3 on the Sony monitor? You should be able to tell a difference in 10:1 and DV25. Any high detail areas should tear up pretty good with 10:1. What kind of connection is going to the Sony monitor…SDI, Component, etc.?
    Also, are you playing them back-to-back? This is the best way to see a difference. If you just click back and forth you are only seeing a single field which is technically half the resolution.
  • Diego Araujo
    March 5, 2008 at 2:49 am
    Hi Michael. Thanks for your answer. I am actually playing them back-to-back. I split the screen in thirds and I am watching the three resolutions at once. Regarding the monitor, I am viewing 16:9, with an SDI connection coming from the Adrenaline box. Is it possible that it’s some kind of software thing?
  • Michael Todd
    March 5, 2008 at 4:29 pm
    Was the footage captured on tape or on P2. If it was tape it is defiantly DV25 resolution on the tape. So 1:1 and DV25 captures will look the same. I would set up the clips horizontally, not vertically, to view one right after another. Keep your eyes on a high detailed area. You should see a shift in the image quality.
    Also make sure your playback is set to greeen/green.
  • Diego Araujo
    March 5, 2008 at 4:47 pm
    Camera was set to standard def, so the footage was captured onto miniDV tape. I am playing back green on green. I will try out setting them horizontally. Will keep you posted. Thanks!
