Activity Forums Avid Media Composer Avid – Recreate boomerang effect
  • Avid – Recreate boomerang effect
    Posted by Jessica Mutascio on February 20, 2019 at 6:23 pm
    Hi everyone,
    Wondering if someone could offer me some insight into recreating a “boomerang” effect in Avid. I’ve been taking an action (whether it be .5sec, 1sec, etc.) and putting a timewarp on the clip to go from 100%-300%. Then I’m taking the exact same clip (starting at the same TC as the forward-moving clip ended on) and doing the reverse; however, it doesn’t seem to be perfectly duplicating the frames. The last frame on the reversed clip does not match the start frame on the forward-moving clip, and I’m typing in the exact same values and using the default curve.
    Is there a way to achieve this look and getting the exact same frames to go forward / reverse at the same exact same speed?
    John Cuevas replied 7 years, 6 months ago 2 Members · 1 Reply
  • John Cuevas
    February 26, 2019 at 4:12 pm
    You could create your time warped clip, do a video mixdown of it – then reverse the mixdown.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
