Activity › Forums › Avid Media Composer › Avid – Reconnecting with R3D Red files
  • Avid – Reconnecting with R3D Red files
    Posted by Matthew Kohnen on May 14, 2014 at 6:39 pm
    I cut a feature on AVID that was shot on RED, and used mxf files during the edit as downres footage. Now I’m trying to get AVID to relink to the original footage, but some of them are relinking and others are not. Part of the issue might be that we’ve had to use different drives spread out on our fibre network, but isn’t this what AVID does? How do I get the project to relink to all my original footage so I can take it to Davinci?
    Michael Phillips replied 12 years, 4 months ago 2 Members · 1 Reply
  • Michael Phillips
    May 14, 2014 at 9:32 pm
    I am going to assume you want to use the R3D files in Resolve? If so, there is no need to relink on Media Composer first. All the metadata should be there for Resolve to conform to. If you want to do a selects only (pull list of R3D), then I would go the EDL route in Redcine X Pro and have it pull entire takes or events+handles and hand that over to Resolve with your AAF.
    Michael
