Activity › Forums › Avid Media Composer › Avid Qualified PC
Avid Qualified PC
Posted by Doug Dillon on January 15, 2008 at 5:53 pmHi All,
I am in the process of setting up an Avid Express Pro HD edit system with MOJO and Studio Toolkit HD. I am ready to purchase an HP xw8400 for the system. My quandary is that I can get a 2 dual core 2.33ghz processor machine for about half the cost of the specified 2.66ghz qualified machine. I am willing to pay what it takes to do it right, but don
Doug Dillon replied 18 years, 7 months ago 4 Members · 5 Replies -
Bouke Vahl
January 15, 2008 at 9:44 pmuneducated guess, if you put the proper graphic board in it will work just fine for SD. I’ve ran MC / mojo on a way slower system. (And i have run NLE’s on 80 Mhz single proc machines with a whopping 64 MB of RAM iirc, installed from a floppy as these systems did not have a CD-ROM. Broadcast video output though, aired on PBS…)
No idea on HD. If you are going to do HD, definitly get all the horsepower you can afford.Bouke
http://www.videoToolShed.com
smart tools for video pro’s -
Michael Hancock
January 16, 2008 at 3:35 amYou should be fine with dual 2.33 GHz processors, but like Bouke said your performance may suffer some if you’re doing HD. Otherwise, it should run fine.
SO why go with 2.66GHz? NLE software is only going to become more and more demanding on the processors and GPU. Get the best you can possibly afford so you can run the system longer before you have buy another one.
My opinion.
Michael.
Accountfrozen_needs_realname
January 16, 2008 at 7:11 pmI hear you Bouke. What was that old system?
How about 16MB on a 25MHz system? Remember the Newtek Flyer? We drove one of those for a few years.
The faster the machine you buy, the longer you go before you have to replace it. That $900 isn’t buying you speed as much as it is buying you TIME.
Jon
_______________
Lack of preparation or organization on your part does not constitute an emergency on my part. -
Bouke Vahl
January 16, 2008 at 8:54 pmNever heard of the Newtek Flyer…
I started out with Amigas, in my last job we had some 24 bits board that could do stills with millions of colors, and it had COMPONENT OUT!!!!
Of course we also had a Targa Video board, connected (component) to a laserdisc recorder to do frame by frame anim recording (driven by a 286).
We once outputted an 30 sec, anim, rendered in a school with a lot of Macs and brought to us on floppy. (yes, we could read Mac files on PC even back then) Uncompressed of course, as image compression was sin back then. 750 floppy discs. Only two failed and had to be re-send.
A year or two later i started my own business and bought a Radius Video Vision and a mac 8100, 4 gig of RAID 0 harddisk and some Ram. Premiere 4.01, could output an EDL with two keys over a dissolve, and a BVE 910 could read it flawless.
But, not the best system back then, just the only one i could afford. (well, not really, it costed more than a year income)After that came a Nubus M100, and that was true broadcast. Still got a lot of material from that 80 Mhz system in my showreel. No one can tell the difference. Not in image quality, not in effects 🙂
Bouke
Doug Dillon
January 19, 2008 at 3:19 amHi All,
Thanks for your insight and taking the time to respond to my post. I will probably go ahead and get the faster machine. I am strictly SD right now, but plan to make the move to HD next year. Even then it will probably be HDV. I’m still sorting through the possibilities of that decision. In any case, it is a point well taken that I should at least attempt to buy a machine with the longest useful life possible.
Doug Dillon
