Activity › Forums › Apple Final Cut Pro › AVID project to latest FCPX- how?
  • Scott Witthaus
    January 18, 2018 at 7:03 pm
    Wow! Interesting. Might have to put Resolve in there somewhere. Can I ask why going to X and back to Avid? Curious about the workflow.
    sw
    Scott Witthaus
    Senior Editor/Visual Storyteller
    https://vimeo.com/channels/1322525
    Managing Partner, Low Country Creative LLC
    Professor, VCU Brandcenter
  • Kent Beeson
    January 18, 2018 at 7:08 pm
    client’s assistant editor cut long string out on an old AVID but I want to edit the doc on my home FCPX system which is faster, etc.
    So was hoping if I knew how to go from AVID to FCPX somehow I would suggest that to client and be able to hand them a file that would then translate well to AVID for their archive.
  • Shane Ross
    January 18, 2018 at 7:47 pm
    There is no way to convert projects…only sequences. Wait, sequences in FCX are called PROJECTS, so this is confusing. You can only convert TIMELINES…not full project, or library, organization. It wasn’t the best idea to have someone do all of the importing and organization and string outs in a different NLE that you are editing in. You’ll spend a lot of time and effort getting it over to the NLE you are using just so you can work.
    But then they want an Avid project for the archive? No…you won’t be able to do that. If this client is cutting on Avid, and wants an Avid project…you need to cut on Avid. You can’t start in Avid, transfer everything and cut on FCX, and then convert it back to Avid. You need to start in Avid and stay in Avid.
    Shane
    Little Frog Post
  • Kent Beeson
    January 18, 2018 at 8:00 pm
    OK thanks – AVID it is
  • Francois Jean
    January 19, 2018 at 1:05 am
    Since AVID original goal was to off line and generate an EDL maybe you could use this path to DaVinci resolve then via fcpxml to the wonderfull FCPX NLE then back to AVID using EDL X … which can convert fcpxml to EDL CMX 3600 which AVID loves.
    my 2 cents
    https://xmil.biz/EDL-X/EDL-X.shtml
    FRANCOIS
  • Shane Ross
    January 19, 2018 at 2:08 am
    [Francois Jean] “Since AVID original goal was to off line and generate an EDL maybe you could use this path to DaVinci resolve then via fcpxml to the wonderfull FCPX NLE then back to AVID using EDL X … which can convert fcpxml to EDL CMX 3600 which AVID loves.”
    Again, this will only convert sequences, not full projects.
    Shane
    Little Frog Post
