Activity Forums Avid Media Composer AVID PROHD MAPPING
  • AVID PROHD MAPPING
    Posted by Earle Nichol on August 9, 2005 at 7:08 pm
    Hey gang just a quick question….am I correct in that AVIDproHD does not have the shortcut for “snap to” editing? I use it on our old meridien Xpress & our DS. Maybe it’s not popular enough for AVID to migrate to this software version. May be we should start a flea market where we can trade in certain shortcuts we never use for ones we need…oops that’s just the garage sailor in me!
    Thanks in advance
    Pearl
    Earle Nichol replied 21 years, 1 month ago 3 Members · 6 Replies
  • Gene Michael patrick
    August 9, 2005 at 8:50 pm
    Avid Pro HD does have the “Snap to” option. Just go to the timeline setting menu from the Project window and select “Default Span-to-Edit” option. Hope that helps.
    Gene M. Patrick
  • Earle Nichol
    August 9, 2005 at 9:02 pm
    Gene, that was the best news I got all day! And at the same time probably one of worst trouble shoots(on my part) ever! Thanks for the tip!
    Luv the cow!!!
    thanks Pearl
  • Earle Nichol
    August 9, 2005 at 9:18 pm
    Hey Gene I knew it was to good to be true. Maybe I’m using the wrong words.
    The “snap to” that I was refering to is the option that allows me to place my cursor on a clip on the timeline and hit my mappable button so from that point forward or behind it, is automatically deleted. It saves me keystrokes of having to put an inpoint & outpoint, and then cutting the shot out. I think AVID may be holding out on this one.
    Thnks for your time!
    Pearl
    August 10, 2005 at 12:53 am
    Hey Pearl,
    Have you tried mapping the segment mode (Red Arrow) to a button? If you select a clip with segment mode, you can lift it out of your sequence without having to set in and out points by hitting Delete. Try that. I use it all the time. Good luck.
    Gene
  • Dennis Kutchera
    August 10, 2005 at 1:24 am
    Its called Top and Tail Edit and it does not exist on XpressPro, yet it was on Xpress Meridien. I loved it too. It may be an oversight. It is hard to keep track of what features to cripple.
    Dennis
  • Earle Nichol
    August 10, 2005 at 7:22 pm
    Hey Dennis
    Thanks for getting my lingo straightened out…Top & Tail edit.
    I miss it so!!! Where does one let AVID know that they should ad this back into the mix??
    Thanks for the help
    Pearl
