Activity Forums Avid Media Composer Avid & Premiere Pro in same pc
  • Avid & Premiere Pro in same pc
    Posted by Robert Bec on June 4, 2006 at 5:50 am
    Hi there
    i need to make a jump to avid as it is our industry standed
    but what i need to know is that i still have to work on prem until i can perfect avid
    can i install avid on my pc without mucking up premiere or vice verse
    i also use matrox rtx100 with prem
    will this disturb the drivers
    Help
    Robert
    Bryantstanton replied 20 years, 3 months ago 5 Members · 4 Replies
  • Mark Slade
    June 4, 2006 at 6:21 am
    I have AXP and Pro 1.something running on my machine….though not at the same time….of course your results may vary…
    Mark
  • Paul Renner
    June 7, 2006 at 5:00 pm
    Works fine, I use both AXP w/mojo and Premiere 2.0 same system. I’ve never used them at the same time, maybe I’ll try that today.
  • Brian De herrera-schnering
    June 8, 2006 at 5:19 pm
    I had to uninstall AXPro so that PPro could output to my deck.
    Brian
  • Bryantstanton
    June 9, 2006 at 2:05 am
    I have both AXP and Premiere (not sure of version) on my comp together, and they seem to work fine, but I’ve never tried running both at once. I have, however, come across a problem that, thinking about it now, only appeared after I installed AXP. Premiere works fine, up until I need to export. Now, no matter what I do, I cannot export from premiere at all. I will click the export button, and bam, Premiere crashes, every single time, without exception. Editing on it, however, works great and I never have any problems. Hm, I will try uninstalling AXP tonight and see if that solves my Premiere problem. I’ll try to let you know my results once I get to test this out…
