Activity Forums Avid Media Composer Avid Playback Problem
  • Avid Playback Problem
    Posted by Mohamed Bilal on June 3, 2007 at 4:18 am
    I just Setup an Editing Suit with Xpress Pro.My Specs are the following
    Intel Dual Cre 3 Ghz
    Asus P5B-MX Board
    Nvidia GeForce 6200 TurboCache AGP card
    2GB DDR2 memory
    350 GB Sata HDD
    and so on….
    when i playback video on xpress pro the color of the video is become too dark.but when i stop the playback or drag the mouse over timeline there is no problem at all.I am using only monitor so it is very suffering to me…Please some one help me and also i want to know that how to setup a dual monitor?It is possible with the above specs?there is any way to get a TV out while editing without MOJO?
    Jhones replied 19 years, 3 months ago 3 Members · 2 Replies
  • Terence Curren
    June 3, 2007 at 7:03 am
    Your nVidia card isn’t set up correctly. You need to adjust the overlay settings so that they match the regular level and then they won’t jump when you play and hit stop. I believe you can find the settings in the install notes or the readme. If not, just play around until it works right.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Jhones
    June 3, 2007 at 7:26 pm
    i believe with your kind a card u can use dual head monitors or one monitor with tv out. and then offcorse u should set the card for what u r doing.
