Activity › Forums › Avid Media Composer › Avid pan & zoom quality issue
Posted by Claudia Samaha on May 3, 2015 at 5:36 pmHello,
I have an issue with avid pan & zoom.
When I import original medias, quality is very bad, while I selected avid ultra quality and rendered.
If you have a solution it would we very helpful.Thanks!
Claudia
Andrew Kimery replied 11 years, 4 months ago 4 Members · 4 Replies -
Scott Freeman
May 4, 2015 at 12:19 amI wonder if this information is helpful for what you are experiencing?
this is what I have been seeing and doing:
Problem: “Avid Pan & Zoom” effect with source files that are not 72 pixels per inch, display in the video monitor soft, resulting in a low quality video look even when rendered as set to high quality.
Possible Solution for files not using 72ppi: Change the Resolution of the file to 72 pixels per inch.
I change the pixels per inch (dpi dots per inch) to 72 and do a save as (I also make sure and not change the original width and height of the source file!!!). I append to the end of the new file “_clean” to the name and then point to the new “_clean” image in the Avid Pan & Zoom effect.
I hope this is helpful!!!
– scott freeman
Michael Phillips
May 4, 2015 at 1:51 amIt seems you have not associated the high resolution image with the effect and are only using the proxy version which is the result of the import. The user guide has a good step step on how its done. But one you place the pan & zoon on the event in the timeline, you need now point it to the external higher resolution file.
Michael
Claudia Samaha
May 4, 2015 at 8:14 amIndeed it works! I just turned into 72dpi in photoshop and I have no problem anymore.
Thanks for your answers!
Claudia
Andrew Kimery
May 5, 2015 at 4:40 pm[Claudia Samaha] “Indeed it works! I just turned into 72dpi in photoshop and I have no problem anymore.
Thanks for your answers! “
I ran into a similar problem on a project a few months ago. The photo scans we received had an insane DPI (like 7200) and when brought into Avid via P&Z they were a pixelated mess. Cranking the DPI down solved the problem. In unofficial testing it seemed like anything above 300 DPI started causing image degradation when using P&Z.
