Activity Forums Avid Media Composer Avid Pan and Zoom suddenly stopped working
  • Avid Pan and Zoom suddenly stopped working
    Posted by Fancyflee on August 28, 2006 at 3:06 pm
    I’m editing on Avid Express DV HD 5.0 on a Mac G5. I’m using Avid Pan and Zoom for my camera moves on my stills and suddenly all my moves have disappeared. The display is set for target and all the keyframe values are still intact. Does anyone know what’s gong on?
    Mike Wolfe replied 20 years ago 3 Members · 4 Replies
  • Michael Hancock
    August 28, 2006 at 3:57 pm
    Have you rendered? Try that, and/or make sure “Render on the fly” is turned on.
    Mike.
  • Fancyflee
    August 28, 2006 at 4:20 pm
    Yes, it is rendered and render on the fly is on. When i try to render it now, there are no camera moves despite the keyframes. Also, when i switch the display to source there is only a crosshair and no white wireframe.
  • Michael Hancock
    August 28, 2006 at 7:04 pm
    I have no idea. Never seen this happen. Has anything been installed on your system lately? And are the pictures you’re panning and zooming on still showing up–just not the moves on them? If the pictures are still there, try reloading them and see if it makes a difference. Otherwise, you have me stumped.
    Mike.
  • Mike Wolfe
    August 31, 2006 at 7:15 pm
    i’ve had a similar issue happen recently. i would press play and the picture would be there, i’d press play again to reveiw the edit and the picture would disappear, i could never tell when it was going to work. this happened mostly when there were multiple pictures in a sequence, usually in excess of 6 or 7.
    what seems to have worked for me, though it may have been coincidence, is deleting the reference files in your “OMFI MediaFiles” folder; the two files ending in “.pmr” and “.mdb”
    good luck to you, let me know how it turns out.
