Activity Forums Avid Media Composer Avid Pan and Zoom flicker proglem
  • Avid Pan and Zoom flicker proglem
    Posted by James Gordon on February 9, 2008 at 7:36 pm
    Hi! I’ve figured out how to work the mechanics of Avid pan and zoom. However, when the photo zooms or pans, a small flicker pops up along horizontal lines, particularly if it is a faster zoom or pan. I’m guessing this is a matter of settings, but I have no idea where to begin to fix the problem!
    James Gordon replied 18 years, 7 months ago 2 Members · 8 Replies
  • 8 Replies
  • Michael Hancock
    February 9, 2008 at 8:33 pm
    In the Avid Pan and Zoom effect make sure you’re render setting is set to Highest Quality, and you may want to try Progressive.
    Michael.
  • James Gordon
    February 9, 2008 at 9:02 pm
    Michael,
    Thank you for your quick response. Let me check my settings. But, do you recognize the problem I’m having?
  • James Gordon
    February 9, 2008 at 9:14 pm
    I see “Progressive” in the Render Mode, but I don’t see a place to set “Highest Quality”…
  • Michael Hancock
    February 9, 2008 at 9:19 pm
    I’m not in front of a system right now so I can’t check exactly where it’s at, but somewhere in the Pan and Zoom effect is a quality setting. Just keeping twirling down the arrows in the effect and all the little fast menus to see if you can find it.
    I may end up going to work this weekend–if I do and you haven’t found it (or someone hasn’t posted another answer) I’ll check it out again.
    Michael.
  • James Gordon
    February 9, 2008 at 9:43 pm
    Okay, I found the AVID Hi Quality setting under FILTERING.
    I’m still having some flicker…here are my settings:
    Filtering: Avid Hi Quality
    Cache: Multi Resolution
    Render Mode: Progressive
  • James Gordon
    February 11, 2008 at 11:08 pm
    These settings seemed to be a big help. If the resolution of the pics was less than 1000 x 1000 or something like that, I replaced them with a larger picture. That seems to have tamped down the problem, for the most part. Not perfect, but not as distracting as before. Thanks.
  • Michael Hancock
    February 12, 2008 at 12:43 am
    Sometimes the lines are just too thin and will vibrate or alias because of interlacing (even if rendering progressive in an interlaced project). I’ve found that taking the picture into photoshop and adding a .5 guassian blur to it does wonders to fix this, but it also softens the picture a bit.
    Glad to hear you’re having success with it. If you want an even better plugin to do pans and zooms on pictures, check out StageTools. Their Moving Picture plugin is great with Avid.
    http://www.stagetools.com
    Michael.
  • James Gordon
    February 13, 2008 at 6:55 am
    Michael, thank you for your attention on this.
