Activity › Forums › Avid Media Composer › AVID Pan and Zoom
AVID Pan and Zoom
Posted by Timothy Lydon on February 19, 2014 at 9:34 pmHello,
I converted a PDF file to JPEG. The quality of the JPEG Is high: 1275 × 1650 but when I used the pan and zoom effect and export, the quality of the image is not good at all. Any suggestions? Thanks! Timothy
Timothy Lydon replied 12 years, 6 months ago 2 Members · 7 Replies -
Ricky Barrow
February 20, 2014 at 2:07 amHate to break the news to you (and I am not being smart about this) – sorry to say that the resolution isn’t even at 1280×720 HD much less full HD at 1920×1080. Typically to do much movement you will need images in the 2-4K pixel range (like 3000×3000 pixels).
Ricky
Ricky Barrow
February 20, 2014 at 2:10 amHate to break the news to you (and I am not being smart about this) – sorry to say that the resolution isn’t even at 1280×720 HD much less full HD at 1920×1080. Typically to do much movement you will need images in the 2-4K pixel range (like 3000×3000 pixels)
If you are careful, not going in too tight and if you render at higher(est) quality within the effect at the highest resolution for your project, you may improve your results.
Ricky
Timothy Lydon
February 20, 2014 at 9:45 pmHi Ricky,
Thanks so much for responding. I used ‘Preview’ on my Mac to convert the PDF to JPEG. AVID wouldn’t allow too large a file but it would import 17,000x 22,000. The quality still looks the same though when I export it. Could it be how I am importing it into AVID? I am using the AVID DNxHD 175 MXF. Could it be ‘Preview’? Would using Photoshop make that much of a difference? Also, what so you mean by ‘render at the highest quality’? I have just been exporting it, I thought the render took place during that process.
Thanks again!
Timothy
Ricky Barrow
February 20, 2014 at 10:59 pmDon’t import – add the effect to filler in the timeline then access the file within the effect through effect editor. OR, if you do import it and use it in the timeline as a placeholder, add the effect to the import BUT still, through the effect editor, link to or access the original file through the effect itself – I have found it best to switch the view mode to target rather than source when setting keyframes for your move. I wish I was in front of the Avid and I could explain how to access the source file (I forget what the button says or what the icon looks like) but you should be able to poke around and make it work – then you render the effect and you will notice how great it looks!
Ricky
Ricky Barrow
February 20, 2014 at 11:07 pmI am out of time but here is a tutorial that shows the effect – go about 2 minutes in to see the part you want.
https://www.youtube.com/watch?v=idPZpekaFcIRicky
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Timothy Lydon
February 22, 2014 at 10:35 pmRicky,
Thank you. I did import the image through the effect and put it on the filler, however, when I export the video, the image looks blurry and not great….I guess I will just have to live with it…
Appreciate your time —
Timothy
Timothy Lydon
February 24, 2014 at 1:29 pmHey,
Figured it out. When I used Preview to export the image, I was using ‘Jpeg’. I switched to Jpeg-2000 with a 1,000 resolution and that did the trick. The image looks good now when I export. Thanks again, Timothy
