Activity › Forums › Avid Media Composer › Avid omfi export question
  • Avid omfi export question
    Posted by Adrian Califf on July 24, 2011 at 6:10 pm
    Hi all I have to make an omfi export
    for a sound dub and was wondering
    if the audio level changes and effects
    etc stay in the omfi or is it just the audio
    with no extra info?. I’m hoping that it will
    stay in there so the dubbing mixer can use it
    as a guide. Any thoughts?..
    John Pale replied 15 years, 2 months ago 3 Members · 4 Replies
  • Shane Ross
    July 24, 2011 at 6:25 pm
    The levels will stay.
    Shane
  • Adrian Califf
    July 24, 2011 at 6:31 pm
    Will audio effects also stay
  • John Pale
    July 24, 2011 at 8:01 pm
    Be aware that on the ProTools side, the sound editor elects whether to import this info or not.
    Many will elect not to, preferring to start from scratch.
  • John Pale
    July 24, 2011 at 8:17 pm
    Depends on what versions you and your audio guy are running. Some may work. None may work.
    You might want to make a wav or Aiff file of your mix as well.
